Does someone know how to fix the gap between the air takes and the clock surrounding? Changed the Clock last week and noticed a gap in between right and left side. Tried to push to the right side and move up the buzel a bit but nothing helped.
remove the air vents and reach in. You’ll be able to adjust the bezel from the inside.
I recently installed a sport chrono clock in my 981CS that was not equipped with the SC option. I bought an eBay clock and trim bezel and cut the hole in the dash to install the clock so I am very familiar with the clock bezel fitment. The only suggestion I would have is to pull out the PCM and loosen the two screws that hold in the clock and slide the clock in the direction you need to center the trim. There are not actual adjustment slots but I think the holes in the clock are large enough to allow a small adjustment.
Jim
