Help - Frunk is locked and can't get in..
#32
Comrade, “not a convenient” is when you have to take off the left front fender and the front left head light in order to open the frunk. For instance this is what I did with my G class with the same issue )))
#33
I you haven't already got a jump starter box, now might be a good time to get one.
Attaching it to the ground on the door and the red pull-out tab in the fuse box will give you enough power to open the frunk.
