anybody useing theAutel 808BT scanner
I’m looking for the best scanner for my Gt4 and a 992 (be here in March) that’s easy to use. I like something that will read over revs reset oil light ,cycle the ABS etc. is the Autel 808BT any good? . Thanks for the help carl
I just got the Foxtel NT530 for my 981 and 991 and it works great. Does everything you list. Reason I got it was because it also actively tests each COV and for the 991 at least, that was an achilles heel and sometimes hard to diagnose. I didn't see that functionality with the other similarly priced units.
Are you sure the NT530 will read OverRevs on the 991 and 981? I can't figure out how to do it on my '14 981. If it does would you explain the menu path how to get there. I couldn't figure it out.
