2013 Boxster 30,000 mile Service
Replacing the coils is not completely bogus. The #5 and 6 coils are prone to failure, especially on the 2014 and older cars. Those two coils are the farthest forward on the driver's side and sit in closest proximity to the cat. I had these two fail within a year of each another at 48K and 64K miles. When they fail, you think you destroyed your engine. It runs like crap, you get all kinds of error messages popping up. It's a pretty scary thing, especially if it happens on your morning commute on the freeway or on a long drive in the middle of nowhere.
The newer coils handle the heat better, but since I also track my car, I added the 991 heat shields to further protect them. Why the 981 doesn't have these is anyone's guess.
So, long story short, do replace the #5 and 6 coils. None of my others have failed and I've not heard reports of any of the others failing on here or Planet-9.com, so IMHO replacing the others is optional.
I DIY'ed the coils and plugs, air filters, heat shields, brakes and fluid (and pretty much all my regular maintenance for that matter). Not that difficult.
The following 2 users liked this post by absoluteczech:
HuskerPete (01-29-2021),
ledbette (01-29-2021)
Location: On a pygmy pony over by the dental floss bush
![](http://www.gtsparkplugs.com/images/porsche-boxster-firing-order-840x.jpg)
So this places the #3 and #6 coil packs closest to the catalytic convertors and they are the most prone to failure, AFAIK. The top of the coil pack is about 1 to 1.5 inches from the cat with sport headers installed, not sure with OEM exhaust, never checked. I have the 911 heat shields installed.
In 911 cars the 9A1 engine is rotated 180 degrees such that cylinders 3 and 6 are closest to the front of the car.
HuskerPete (01-30-2021)
You are correct. I misstated. The 5 & 6 are the closest to the rear... Due to the arrangement of the engine and exhaust, the cat on the driver's side sits closer to the engine than the passenger side. So 5 & 6 sit closer to the cat than 2 & 3.
Service is by year/mileage...the 3 year/30000 mile service should have been done 4-6 years ago.
Most of these cars are serviced by year, regardless of mileage.
Do you have the service manual? What is your in-service date? Manual or PDK?
Anyway, if you assume nothings been done get the service manual actions up to date, which for you should be everything up to year 7/8.
I just bought plugs and coil packs from Pelican. I'm getting a misfire on cylinder #2 and my Boxster is a 2014 (non S) with mid 30k miles. I just pulled the wheels and the inner fender and wow - this looks to be a major pain. It doesn't help that there are sharp metal edges close by.. I'm starting to reconsider my decision to do this myself. It is really tight on the 2014 Boxster. I watched some of the videos of other models and they looked to have more room..
Diamond Dave (02-17-2021)
These are the what seem like the most common things that come to mind.
Coils 5 & 6
Door panel warping
Coolant cap warping/leak
Windshield washer tube break at hood junction
Headlight delamination
PCM rebooting due to HDD issues
Hood latch sticking (need to lubricate)
(Cayman) headliner
Of those, I think the only expensive items are the door panel warping and headlight delamination, and headliner droop if you go with a Cayman. These are all appearance issues. Compared to the bore scoring, chunking, spun rod bearing or IMS issues of the 986/987, we have it pretty good.
If you track your car, there are a few other things to keep an eye on.
Coolant pipe drain plug crack
Stripped brake caliper bolt threads in front uprights (use aftermarket studs instead)
Exhaust manifold weld cracks
maschinetheist (10-14-2021)
Those are pretty easy to get to. Farthest to the rear, right above the cat on the driver's side. There are a few lists floating around of common issues. We need a sticky for those things.
Coils 5 & 6
Door panel warping
(Cayman) headliner
Coils 5 & 6
Door panel warping
(Cayman) headliner
I was really enjoying the car, but didn't totally love how the steering felt with all the weight in the rear. It was like driving a small speed boat. I'm looking forward to trying some Boxsters and Caymans. I've driven them in the past, years ago and briefly. Really liked them. I'm old school muscle primarily, but love a small, good handling car. I have a Cobra (the ultimate cross-breed between small and muscle) and a new GT350 now (best handling car I've ever driven to date. It REALLY does run dead even with GT3's. Ask me how i know. LOL).
Anything more to add to that "things to look for" list that anyone thinks of, please feel free to add it. I'll keep looking. I'm in no rush.
THANKS!
In addition to the MA1 engine, which seems to have solved all of the reliability issues of the M96/M97, the electric power steering solved one of the other big reliability complaints. The electric power steering really is pretty darn good. Most of the issues now seem to be cosmetic or minor repairs. There have been a few cases of PDK failures, but those seem to be pretty isolated.
