CTEK and 981 Cayman
I have successfully used CTEK MUS 4.3 with my 981 for over two years, connecting through the cig lighter. The CTEK behaved "by the book", running through all stages of the charging cycle up to the green “Fully Charged” light.
Recently, the CTEK behavior changed. It will now cycle up to the fourth light, and turn off before getting to the fifth light. I haven’t made any changes to the 981 settings or the CTEK. This new behavior is confounding.
I called CTEK support. Their diagnosis is that the 981 is going into a sleep mode, and disconnecting the battery from the cig lighter. Upon sensing this, the CTEK turns itself off.
Does anyone have any advice as to what may have caused this change in behavior?
Thanks for any insights.
My conclusion after looking at the terminals inside the cable ends of the CTEK before I threw it in the trash is they appeared to show signs of over temp, I believe because of poor quality material selection or poor manufacturing of the cable itself. Not a consistent, tight connection. The loose connections led to high resistance, overheating, and incorrect performance. With a high quality cable and connector terminals it might have lasted for decades, but there was no way to fix the cable end without cutting it of and soldering on a new type on each end of the mating parts. No more CTEK in my household. Some will probably reply to this thread saying their CTEK has lasted for years and years. I suspect somewhere in those years CTEK changed their connector component design or sourced them from China or elsewhere of similar quality. Just telling you my experience. And I'm careful with my equipment, I don't abuse tools or connectors. It was an inferior part of what might be a superior electronics package that ruined me on CTEK. YMMV.
Edit: Whoops didn't see that you've been successfully charging this way before. Mine never worked from the start. Know anyone else with a CTEK charger to swap and rule out the charger itself?
If the car is unlocked it will turn the charger off after 30min.
With the car locked the charger will fully charge and the socket will stay live.
Hope that helps.
