981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
Mechanic underfilled oil
Old Sep 6, 2020 | 08:59 AM
V987S's Avatar
V987S
Default Mechanic underfilled oil
Hi guys,
Recently acquired 981 Cayman S and already feeling quite nervous about recent oil service at a specialist where mechanic put in roughly 5.5litres of mobil1 before starting the car and letting it idle to warm up (for a while must I say) in order to check oil level.
no test drive was performed but it was left sat idling for 15-20 minutes.
The screen then indicated Min. Level reached with 5 empty bars and yellow oil symbol lit.
Mechanic then topped oil to 4/5 of indicates bars.
Could they have damaged the engine in the long run?
thanks
Old Sep 6, 2020 | 09:08 AM
ekam's Avatar
ekam
Just change the oil yourself. It takes the longest to drain the oil.
Old Sep 6, 2020 | 10:08 AM
danschy's Avatar
danschy
I'm no engine expert, but I don't see how the scenario you describe could have damaged the engine. If there was so little oil that the oil pressure warning light came on, then I would be a little more concerned.
Old Sep 6, 2020 | 11:11 AM
85Gold's Avatar
85Gold
Your fine, now being 2.5qts low and on track might be an issue.
Peter
Old Sep 6, 2020 | 12:12 PM
V987S's Avatar
V987S
Thanks guys
very comforting to know!
The mechanic was initially hesitant when asked about the exact number of litres he had put in.
He initially said he had put in 6 to 6.5 litres (6.3-6.8 quarts).
But I was present when the car was idling with the Min. Reached and oil light lit, so he said there was around 2 to 2.5 liters (2.1-2.6 quarts) left in the second 4-litre Mobil 1 bottle.
so logically I hope he did put in at least 5.2 quarts in the first fill then top up the remaining after idling the car.
Old Sep 6, 2020 | 12:29 PM
jscott82's Avatar
jscott82
That's standard procedure. I don't know capacities of the 981, but SOP is to underfill by a quart or 2 (as long as it's making pressure) let it get to operating temp, then top it up.
Old Sep 6, 2020 | 12:30 PM
Bxstr's Avatar
Bxstr
That's normal. Nothing to be concerned with.
Old Sep 6, 2020 | 12:45 PM
Viper pilot's Avatar
Viper pilot
Trust your mechanic for cris.... sake. Geezzz!!
Are you sure that's 93 octane coming out of that pump sir. I thought I saw the truck filling the tanks with mouse ****!!!!
Old Sep 6, 2020 | 12:47 PM
Marine Blue's Avatar
Marine Blue
Agreed, that’s what my porsche tech does too, it insures that you don’t overfill which can cause issues. Although typically he’s only off by a quart
Old Sep 6, 2020 | 01:57 PM
V987S's Avatar
V987S
Thanks again, guys
I think it was off by a little more than 2 quarts
car was started and left to idle for 20 minutes, then oil was topped off
now I think I can sleep well!
Old Sep 6, 2020 | 01:58 PM
KBell's Avatar
KBell
Agree with above.
Hardest part is backing the car on ramps.
Oil changes are otherwise not bad at all.
Rennlist can always help with any small detail if there is a problem.
Welcome!
Old Sep 6, 2020 | 02:38 PM
V987S's Avatar
V987S
would underfilling by 2.5 quarts reduce oil pressure?
Old Sep 6, 2020 | 03:06 PM
jscott82's Avatar
jscott82
It's either going to make pressure or not... As long as the pump intake is submerged it will make pressure.
Would not want to try it but I'd bet it only takes 3-4 qts of oil to submerge the intake on level ground.
Old Sep 11, 2020 | 12:11 PM
V987S's Avatar
V987S
I hope I am not being hypersensitive but have noticed cold starts are pretty loud (ticking noise sounds much louder than my old 987.1S)
is this normal for cold starts? Car does this almost every cold start now.
Old Sep 11, 2020 | 04:01 PM
cjrhoades's Avatar
cjrhoades
Sounds normal to me. The "ticking" is the injectors firing. DI engines are noisy.
