Building a better 981 GTS?
Strongly considering a 981 Cayman GTS as my next Porsche. But with the premium folks are asking over a 981 Cayman S, I’m wondering if it’s easier or cheaper to build a GTS beater via the aftermarket.
I could pick up a manual 2015/16 Cayman S for probably 15-20k less than a GTS, and that could buy a lot of aftermarket parts: coil overs, sway bars, tune, exhaust and/or headers. I’d be happy with 350 HP and a setup that would outperform a standard CS on road and track. I would miss the alacantara goodies, though.
Thoughts or recommendations? I’m sure I’m not the first to go through this mental exercise.
If its just performance you can get the x73 suspension that the GTS has for 1500$. Add a Cobb tune to bump hp to 350 (360-370hp if you throw in headers) for another $1300 and you will basically have the same car. I believe the GTS also comes standard with the 3rd radiator which you can also add for 1000$. Its up to you if the GTS badge is worth the extra $$ to get the interior bits and the different front bumper.
Also x73 suspension is fantastic for the price, lowers the car 20mm and the handling is perfectly balanced from the factory. This is what I did to my 981CS (minus the 3rd radiator and headers) and I couldn't be happier with the car.
g00dparsh (07-21-2020)
Can be very easily done. When I bought my S, I was also looking at some GTS' but the price difference didn't make sense since 80% of what you're getting can be optioned on the S (minus the 3rd radiator, extra HP, some aesthetics). Find an S with x73 suspension, PSE, and sport chrono and you're basically there. As a new car, the GTS is a good value because it's cheaper than optioning up an S, aftermarket, a highly optioned S becomes a much better value.
Location: On a pygmy pony over by the dental floss bush
There are three things on a GTS that if you want them, might be cost/difficulty prohibitive.
1) PASM - many GTS cars were built with X73, so all depends on what you want on your converted Boxster S
2) GTS interior option - lots of alcantara and leather, very few Boxster S cars were decked out with this much interior leather and alcantara
3) GTS front and rear bumper cover - bespoke to the GTS, available at any Porsche parts dealer, the front will also require a center 3rd radiator.
The GTS had PSE standard. Quite a few Boxster S cars did not, like mine. I added it for a total cost of ~$2,100 with new Porsche parts and dealer labor.
The engine performance difference can be achieved with an aftermarket ECU flash tune, with a pro tune custom for your car being the preferred method.
In the end it comes down to effort. If costs are really upwards of a $15k premium for a GTS over an S, then there's no question you could get the requisite parts for less than that. But then comes the installation process. If you have considerable experience and enjoy wrenching, then by all means go for it. If your plan is to have someone else do the work, it probably won't be worth it in the end. It may end up costing more, depending on how much labor is involved.
There is also the concept that the GTS package is a "greater than the sum of its parts" kind of thing. It's one thing to have the exterior aesthetics, but I don't think you can get the interior package outside of finding a car with it equipped (ruling out chance salvage situations). Performance-wise there's no doubt you could build a more capable car. The ECU tune alone for example; last I recall a Cobb OTS tune netted more power gain than the GTS package.
Also as an aside, it's hard to find it documented anywhere but I've read in one place or another the GTS has a bespoke "sound symposer" system and the intake manifold is specific to the GTS. Not sure how much validity is in that though so don't take my word for it.
The symposer connects to the firewall behind the seats at shoulder level in both the BGTS and CGTS. To be clear, it is just a waveguide, not a speaker. I wouldn’t miss it if I didn’t have it...
Originally Posted by Kancamagus;[url=tel:16772906
16772906[/url]]The symposer connects to the firewall behind the seats at shoulder level in both the BGTS and CGTS. To be clear, it is just a waveguide, not a speaker. I wouldn’t miss it if I didn’t have it...
I’m actually gonna stick a little acoustic foam in it just to see what it is contributing. But having driven other non-symposer cars I already know its not much... Inside, or outside, the cabin the S really doesn’t suffer an absence of aural character, especially with PSE, which is std. on the GTS. So I dunno why Porsche felt compelled to add it - maybe it was in response to all the synthesized crap coming through the speakers of those other, unconscionable, German marques.
Your money will be better spent getting a gts directly if you don't plan to hold on to it forever. I see they've come down in price a bit already, can be found in 50s with reasonable mile/shape
not in the market but each time I'm doing a search every 2 mon or so for fun, I def can see 1-2/several under 60, didn't check the specs tho. After all they are not that special/precious.... Actually 18 months ago I almost bought a pdk bgts with 10k miles a tad under 60k, pdk/ptv/x73, decided I don't like the x73's ride.
And isn't there is 1 or 2 for sale here asking 5x? Def saw 1-2 like 2wks ago in for sale section
