981 Forum Discussions of the 3rd Gen Boxster and 2nd Gen Cayman (2012-2016)
981 PPI Results
Old 05-31-2019, 07:09 AM
DBKY
DBKY's Avatar
Default 981 PPI Results
2014 Boxster Base - 1 owner - 66k - Clean CarFax, no accidents. Alll scheduled maintenance done on time at the dealer. Price seems to reflect the miles. Got a PPI done yesterday and a few items to note:
DME DTC CODE Present P1672 engine compartment purge fan electrical fault
AIRBAG DTC STATUS Present Passenger's airbag indicator light, CAN wrong feedback
INSTRUMENT CLUSTER DTC STATUS Present Warning: Doors/front lid open when driving
PARKING BRAKE DTC STATUS Present Drive away release, not available
FRONT END ELECTRONICS DTC STATUS Present Key not synchronized
The driver's side fender is out of alignment and rubbing the driver's door.
The driver's door weatherstrip is worn through.
The horn button sticks and the horn does not work - (Note: a $1500 part per the dealer).
I'd noticed in some pictures earlier that the side marker lights had been changed from clear to amber sometime in the vehicle's life. Personal taste maybe, but I was suspicious that there was some undisclosed body work done. With the fender and driver's door not fitting together correctly it looks like this one had a rougher life than the Carfax would imply. Not sure what to make of the other DTC results. But, since I don't have any way to see or drive the car prior to purchase, I think I'm passing on this one. Any thoughts?
Old 05-31-2019, 07:30 AM
manifold danger
manifold danger's Avatar
Received 1,133 Likes on 638 Posts
From what you're describing, I agree. Too many unknowns, and already enough baggage to move on.
Old 05-31-2019, 08:24 AM
fgv1it
fgv1it's Avatar
Agree. There is no reason for a fender to be mis-aligned on this car, other than a mishap that is not being disclosed to you. Pass. There are enough cars for sale out there for you to be able to find the one you want without any history.
Old 05-31-2019, 01:40 PM
vracer
vracer's Avatar
I think you have a quorum here.
Old 05-31-2019, 01:41 PM
DBKY
DBKY's Avatar
Yup, I concur. Thanks all.
Old 05-31-2019, 03:09 PM
flat6ftw
flat6ftw's Avatar
This is a very easy call.. HARD Pass
Old 05-31-2019, 03:31 PM
SpyderSenseOC
SpyderSenseOC's Avatar
Received 1,321 Likes on 789 Posts
Next.
Old 05-31-2019, 04:23 PM
SoCal-NSX
SoCal-NSX's Avatar
The thing about the fender rubbing the door was enough....
Old 05-31-2019, 04:27 PM
Moman
Moman's Avatar
The hunt continues.
Quick Reply: 981 PPI Results
