Grinding noise from steering column - 981
My 981 Cayman is making grinding noise near the steering column. It's sounds like plastic rubbing, doesn't happen constantly, and is not speed-dependent. Any guess as to what might have caused it?
you can pop the steering wheel off. it's really easy if you have the right 12pt. just need a new $9 bolt as it's not reusable. maybe its dirty or just needs some lubrication in the column.
