92 968 unlocks when I try to lock it
Ran into my first 968 electrical gremlin. The other day I went to put something in the passenger side footwell not realizing the car was locked, and set the alarm off. Opening the drivers door with a key silenced it.
Ever since then when I go to lock it turning the key in the drivers side lock it will lock but instantly power unlock.
Anything in particular to look for? Bad power lock solenoid?
I think it could mean there is an open circuit in the system. (bad pin switch) You might try checking the door pin switches as well as the rest. I could be wrong here but this is what I think I remember reading.
Does the power lock on the passenger side work? The solenoids are 5 wire, meaning there are wires to let the alarm module know if the locks are in the lock/unlock position. I would bet yoir passenger side solenoid is dead, which you explain why the alarm went off when you opened that door.
