Help with headlight assembly removal
Hi guys. I'm trying to find a step by step to remove the headlight assembly to replace the headlight surround (pn 944-750-151). Can anybody direct me to a step by step how to do this? I can't seem to find anything. Thanks so much! :-)
Registered User
If you are only replacing the headlight surround ( I'm assuming the body colored piece) just three screws is all.
Well...you could take the long route.
First, remove the fender liner, then remove the fender, then remove the entire headlight assembly and place it on the workbench.
TA-DA!!! - easy access to the entire headlight.
