Rear wheel offset. ET40 fit on 968?
No simple answer here hot-j. If you are talking about using an 8 inch wide wheel then 40 might be fine - but I suspect you're not. And the answer cannot just be spit out because it depends on a combination of variables consisting of:
Which wheel and tire you choose
How much negative camber you plan to run
Vehicle ride height
Suspension travel
How far you intend to roll those quarters
Perhaps someone here has accomplished this and can comment more
Vehicle ride height
Suspension travel
I am presently running:
18 x 10 ET 62
265 / 35 P Zero
1.5 neg
ROW height
If I were to change ET by 22mm (almost 9/10s of an inch) a fender roll would be mandatory. Be warned - a friend of mine rolled his using one of the popular aftermarket devices and cracked a lot of paint. My son and I rolled one of our Nissan 240SXs easily with no paint damage but the rigidity built into our wheel well arch makes the task more difficult and can crack paint.
18 x 10 ET 62
265 / 35 P Zero
1.5 neg
ROW height
Correct on rear ET for the (very few) factory turbo cars but those wheels are 11 inches - at least the turbo RS were - I'm assuming turbo S was also
OEM 968 Turbo S Wheels.
Front: 8J X 18 ET 52 part number 965.362.136.01
Rear: 10J X 18 ET 61 part number 965.362.140.01
OEM Tire size,
Front: 235/40-18
Rear: 265/35-18
My hollow spokes were the same size front, 10J X 18 ET 65 Rear wheels. I ran two different size tires in the rear. 285/35-18 which would rub under full compression. Swapped to 265/35-18 R Compound's.
OEM Tire size,
Front: 235/40-18
Rear: 265/35-18
OEM Tire size,
Front: 235/40-18
Rear: 265/35-18
Turbo RS...?
OEM Tire size,
Front: 235/40-18
Rear: 265/35-18
OEM Tire size,
Front: 235/40-18
Rear: 265/35-18
Seems like I could have remembered that.......
