FS: 93 Firehawk 968
I’ve owned since 2003 and have over $85,000 in receipts to indicate the level of detail in maintenance and enhancements since purchase. This car was built by Dave White in 1993 to compete in the IMSA Firestone supported Firehawk series. The cage has the original IMSA stickers still in place. This is not a replica Firehawk that you see at the track periodically.
Currently configured for PCA SP3 or F Stock
This car has been exquisitely maintained by Precision Motorsport Racing in Califon NJ since purchase in 2003.
All fluids changed after every race weekend.
Corner weighted and balanced at least 3 times per season to optimize dialing in of suspension. Have all the spec sheets.
Wired for cool shirt and helmet and radio
Outline of major work done
Within the last 3 years:
Complete engine rebuild by Michael Mount with the best of everything. Approximately 25 hours since the rebuild.
Guards LSD
Moton Club Sports - 600lb front / 250lb rear spring set up
Clutch
Starter
Alternator
Power steering rack and pump
Borla exhaust
Battery
Replaced Fab A-Arm pins
Solid suspension bushings throughout
New window net
Schroth belts
Updated fire system
Belts
18 inch Enkei wheels
Within the last year:
New front rotors and calipers
New rear rotors
New Master Cylinder
Front hubs (Racers Edge)
Rear axles
Control arm pin servicing
Polybronze bearings & rear spring plates
Guards LSD
Clutch
Starter
Alternator
Borla exhaust
Battery
New window net
Schroth belts
Updated fire system
Belts
New rear rotors
New Master Cylinder
Rear axles
