968 Forum 1992-1995
Speaker Grills - '95 968
Old 10-10-2012 | 08:34 PM
miramar_trieste's Avatar
miramar_trieste
Default Speaker Grills - '95 968
Hey everyone.....recently I noticed the black metal grills on both my driver and passenger drive doors are starting to rust, and want to know if anyone knows where I can pick up a couple more to buy?
Or would it be easier to remove them and just paint them myself? Not sure how easy they are to remove...
Any advice is greatly appreciated...
Old 10-10-2012 | 09:16 PM
RL911's Avatar
RL911
They are easy to remove, just a few screws around bottom section of the door to get at the speakers.
Old 10-10-2012 | 10:49 PM
odb812's Avatar
odb812
I think I have an extra set in good condition, let me check the garage this weekend.
The grilles are easy to remove from the panel, but you face two challenges with the grille cloth. First is getting it off cleanly, which is only really important if you plan on reusing the existing cloth. The second is sufficiently tacking the grille cloth back onto the grille without glue residue showing through.
Old 10-11-2012 | 10:17 AM
CurtP's Avatar
CurtP
I just left the cloth off of mine. Can't really even tell.
Old 10-12-2012 | 05:51 PM
DiREW0LF's Avatar
DiREW0LF
I removed mine, stripped off the cloth then repainted them. I was able to obtain the fabric from a local high end home theater store and glued it back on with contact cement.
I was able to use a rubber wheel to remove all the excess fabric (more like paper). Then its just a matter of carefully applying the contact cement to the grill being careful not to get any in the holes or on the newly painted side, then press on the fabric being careful not to get wrinkles. Cut the excess, reinstall and enjoy.
Make sure whatever fabric you get is accoustic, don't want to block the sound from your speakers.
Old 10-12-2012 | 06:14 PM
miramar_trieste
Thanks for the feedback...I'm going to give it a shot....
Old 10-12-2012 | 08:34 PM
TheBlau's Avatar
TheBlau
might as well replace the speakers while you're in there :P
Quick Reply: Speaker Grills - '95 968
