Door window removal, help!
I'm replacing my driver side door due to rust getting in and eating up one of the hinges. It actually broke today.![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
I have a spare door prepped for painting but I have no idea how to remove the driver side window from the door.
I checked Clarks-garage with no luck.
Anyone know how to do it?
You have to undo the window motor, think there is 4-5 bolts holding it, then you are able to like the window motor arms out of the channels at are at the bottom of the glass. The glass then should come out the top. You will probably have to remove the window scraper trim also.
Hope that helps.
Hope that helps.
