Fan problem...
Hi all,
I have an issue with my fans...
Yesterday they start making alot of noise and starting every 2 seconds!!!
The engine is not heating, weather is normal (25degree)...
Can it be the thermostat? or do you have another idea of what it could be?
open up the fan relay cover carefully ,brush the dust from the board and spray contact cleaner on the
4 relay contacts as well as the back of the board.Leave to dry and refix.
95% the problem will be gone,as opposed to appx 200 usd of a new relay.
Could also be the thermo switch that is screwed into to radiator. IIRC, it was relatively cheap and easy DIY job. Clean the relay first, if that doesn't work then I would try the thermo switch replacement.
