968 Forum 1992-1995
Sponsored by: HBI Auto
Starter Ring Gear
Old May 20, 2011 | 12:39 PM
9ines's Avatar
9ines
Question Starter Ring Gear
Any tips for removing the starter ring gear from the Tip damper? I've tried heating it and then banging with a soft mallet, but it doesn't budge. No rust, just a very tight fight. I'd like to avoid taking it to a machine shop, but I don't want to damage it.
thanks,
-kb
Old May 20, 2011 | 11:40 PM
9ines's Avatar
9ines
Solved. I soaked the rim in PB for a few hours and was able to pry it off with a mini-crowbar.
-kb
Old May 21, 2011 | 04:16 PM
968 GUY's Avatar
968 GUY
Some heat would have done it. Get a heat gun, and it does not normally take a lot to expand the ring just enough to remove or install, just focus the heat on the gear.
When you go to reinstall, put dampener on ice,in freezer, whatever, and heat ring gear.
