Advice. Rear Exhaust Muffler 968
![Lightbulb](https://rennlist.com/forums/images/icons/icon3.gif)
was thinking how nice it would be and sound if i custom made a rear box
or i take of Rear Exhaust Muffler and have a straight pipe
what you reckon![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
i just think it sounds to silent and i just want a nice rore
hope you know what i mean
what you reckon
Well if you want to go the conventional way and purchase an already made one. Here are some sound clips. http://www.youtube.com/watch?v=54T8ubJH5Tg
Team Owner
Location: one thousand, five hundred miles north of Ft. Lauderdale for the summer.
i think i'll go throw up now.....
instead; start with a 2 1/2" test pipe.... run into a single SLP 2 1/2" in/out 4.5" loudmouth hollow chamber resonator (summit and jegs both sell the loudmouth in single units)...
don't let the name fool you. that resonator really cleans up the exhaust note.
http://www.summitracing.com/parts/SLE-310013919/
next, run into a 3" in/out 5" X 8" X (18" or 22") straight through Magnaflow with offset outlet. both will be loud enough, but the 22" is the better choice in my opinion.... should run about $550 for the entire system including fabbing a pipe with 2 - 45 degree bends.
your engine will sound amazing.
instead; start with a 2 1/2" test pipe.... run into a single SLP 2 1/2 in/out 4.5" loudmouth resonator (summit and jegs both sell the loudmouth in single units)...
Maybe I still could.
Do you have a similar set up on you car?
Plus an audio clip. That would be awesome.
Team Owner
don't try it. in California you're simply, totally screwed.
i'm no longer running the hooker muffler. i changed to a 3" pipe and extremely large Magnaflow straight through muffler after the resonator. i was dying to hear how it would sound with a really noisy engine... the Magnaflow measures 5" X 11" X 22". so the entire exhaust is a 100 % straight though system that is very quiet but still makes a nice sound at wot with the current engine.... it should also sound great with the new V8 (save for the triangular resonator that i'll add to confront the sound after the Y-pipe).... i'm sure the regulars that read the forum daily are sick of me droning on about exhaust parts. so i'll shut up now.![Cool](https://rennlist.com/forums/images/smilies/cool.gif)
You dont want a straight pipe...you won't like the sound and it will be too loud. You will also lose some midrange power.
If you just want a nice sound, get a B&B TriFlo cat-back. Those sound best and look the nicest.
Make sure you buy a 2.5" Catback if you get one. A 3" is too big and you will see a lose in power as there wont be enough backpressure.
Going cat-less is pointless. You will gain 1-2BHP without a cat. Only you will pollute more, wont pass inspection in many states, and the car will be way way too loud for most people to enjoy. It will also sound like a slightly throaty Honda with a fart can.
A B&B Cat-Back with the Aribox mod will give you a nice sound from both the exhaust & engine.
Team Owner
ask Van about my sound... sounds so good now, i'm actually sad to see it go.
i'll also stop by so you can hear it, Dino before Van pulls the engine out in July.
Please keep in mind that an exhaust system is no less intricate than any other part of the drivetrain. There is engineering that goes into it, and you will find if you just try different mufflers, pipe diameters, bends, lengths, etc you will spend a lot of time getting the noise you want, and you still might not have the powerband you want. So basically, don't expect miracles if you DIY. ![Smilie](https://rennlist.com/forums/images/smilies/smile.gif)
I agree with fox, keep the cat. If you need more flow, modern hi-flow cats are what you want. You'd be amazed how much they flow, and you won't pollute. Cats aren't bad, it's old fashioned cats that are restrictive.
I've heard many of the 968 catbacks available on the market. IMHO, the B&B sounds way better than anything else - perfect note(s), perfect volume. I once was unfortunate enough to be gifted by my car with a catback bypass. It sounded awful, and loud.
If you don't like the idea of cutting your expensive and rare Porsche plastic airbox, an aftermarket cone filter will sound even louder and they're easy to swap on/off. Just my 2 cents.
People in California are best suited to answer questions about exhaust systems for CA cars. You have many options that will all pass smog easily, not pollute like the evil kitten-murderers that run a test pipe, and give you whatever you're after, be it power, sound, or both. Or the actual ability to pass smog if your problem is a bad cat.
