968 Maintenance Catch-Up
So, about a month after I buy my car, the flex damper goes to shreds (one day after the warranty expired, BTW). I've decided to get current on all of the engine maintenance at once.
The belts and rollers were done at 64K, Unfortunately, that was in May 2002! The car now has 96K.
Here is my parts list. These are all of the things that I will replace. I would appreciate any advice here:
Transmission flex damper
Flywheel/RMS
Timing/Balance belts and rollers (Any kit recommendations?)
Balance shaft races
Camshaft chain
Camshaft pads
Front engine seals
PS belt
AC/Alt belt
Valve cover gasket (full kit)
Manifold gasket (thicker thermal version)
Air filter
fuel filter
Distributor cap and rotor
Spark plugs and plug wires
I will also add an RSB stage 1 chip and the RSB cat-back while I am under the car.
Have I missed anything? I'm not planning to replace the water pump or TB tensioner unless I see something bad when it all comes apart.
thanks,
-kbarber
Flywheel/RMS
Balance shaft races
Camshaft chain
Camshaft pads
Front engine seals
PS belt
AC/Alt belt
Air filter
fuel filter
thanks,
-kbarber
if you're going to all that trouble, may i ask why you wouldn't just replace your water pump? its not usually the belts that break by themselves, its the pump seizing that causes the belt to break...
also, rod bearings would be a good idea at your mileage. you'd be ok with another 20-30 thousand miles probably but just something to think about!
Good luck, i just went through my maintenance overhaul last fall!
No need for manifold gasket or ignition wires IMO. Would replace heater control valve when you do belts and agree that water pump should be done @ the same time. Rod bearings aren't necessary but you might wanna do them eventually at the same time as engine mounts. Additionally, I know it's not engine maintenance but how about flushing brake fluid and new transmission fluid/filters as well [sounds like a Tip with flex dampener]?
Are the much cheaper rebuilt pumps okay?
thanks,
-kb
