Any 968 owners semi-local to Seacoast area NH? Help needed.
4th Gear
edit: wrong forum! I need a *964* not a 968, sorry bout that!
Hi all,
I've been working on a VEMS 964 plug and play standalone ECU for a customer, and I'm at the stage where I need to do some testing to verify the trigger and output settings. My customer unfortunately is not local. What I need is access to a running 964 ('stock' preferred by as long as it still runs a factory ECU - even if chipped that should be fine) so I can temporarily install my system and run some diagnostics to make sure my configuration and hardware setup is good before shipping off the ECU.
I guarantee no harm will come to your car. I should be able to complete the testing I need to do within an hour or two. Definitely willing to buy your beer of choice for the trouble!
If you can help, please contact me. The closer to 03824 (Durham, NH) the better but I'm willing to travel up to 100 miles if necessary. Thanks!
-Marc-
Hi all,
-Marc-
Last edited by a4kquattro; 04-09-2009 at 05:39 PM. Reason: temporary stupidity - posted about the wrong model.
4th Gear
