Zero Tolerance In 968 Forums
It has come to my attention that 968 forum needs to follow the same policy that JD implemented to the 944T a while ago. We would appreciate it if 'all' people would read it, follow it, and act accordingly. Thanks for your support.
Zero Tolerance In the Forums
There is now a zero-tolerance policy in effect for harassment and off-topic bickering in the Forums. Its fine to disagree. Its fine to debate. It is fine to argue in a mature manner.
It is NOT fine to cast third-party suspicions, as a 3rd party or competing supplier - calling a vendor shady, and/or slandering a supplier or person in any public forum. Rennlist is certainly no exception.
So here is some advice If you are thinking about posting a reply which you wonder will John D. ban me for this? presume the answer is YES and dont post it.
If someone is harassing you in technical threads report them and never respond to them. If you participate even to defend yourself you are part of the problem and are just as guilty.
This is your only warning. If you participate in off-topic bickering, slander or harassment in the technical forums you will be banned from Rennlist.com
Lets keep the Forums technical.
John D.
