Track tire pressure - what do you all run?
I am running R888
Cold psi (at start of session)
F. 27
R. 30
Hot psi (at end of session)
F. 32-33
R. 37
Outside temp: 103 degrees (very hot)
Car felt good / balanced thoughout session
F. 27
R. 30
F. 32-33
R. 37
Rob,
I'm trying to keep my pressures the same all the way around.
If I had a pyro, that would really be the gauge I'd be using...but I don't, and the time factor is even more critical with temp's than pressures...and I don't always have a track-rat at the ready, either!
So, I'll stick with tire pressure as the barometer...Anyway, I'm not a podium contender at this point, so it's not that critical anyway!
I try for fairly even f/r pressures although you can you pressure to finetune the handling. If pressures are like the RA-1 I ran those at more like 38-40 psi hot.
MIke
MIke
I run Hoosier R6's and aim for 39psi all around when hot. Usually start around 32psi cold and have full temps after 1st run of the day. I bleed down when the ambient temps are hot and tire temp's exceed the targeted 39psi.
I have used a pyrometer but use tire pressures far more frequently.
35-36 hot all around on 245/15's (R6). Pyrometer readings from 185 to 195 on pit lane.
I run the 888's the same but on 235/15's.
32-33 hot for your front tires seems too low, unless your car is sub 2000lbs?
