Compression/Leak numbers
I had a PPI done by our Porsche centre a 92 968 with 112 500 miles.
These are the numbers: (Sea Level) Any comments are welcome.. based on these, I need to make decision to buy or not. Thanks
Compression Test - dry
Cold
Cyl1 1300 kpa - 188.5 psi
Cyl2 1325 kpa - 192.1 psi
Cyl3 1275 kpa - 184.9 psi
Cyl4 1275 kpa - 184.9 psi
Hot
Cyl1 1275 kpa - 184.9 psi
Cyl2 1300 kpa - 188.5 psi
Cyl3 1250 kpa - 181.2 psi
Cyl4 1250 kpa - 181.2 psi
Compression Test - Wet
Hot
Cyl1 1400 kpa - 203 psi
Cyl2 1400 kpa - 203 psi
Cyl3 1450 kpa - 210 psi
Cyl4 1400 kpa - 203 psi
Leakage Test - Dry
Cold
Cyl1 20%
Cyl2 16%
Cyl3 24%
Cyl4 22%
Hot
Cyl1 12%
Cyl2 14%
Cyl3 18%
Cyl4 19%
Leakage Test - Wet
Hot
Cyl1 12%
Cyl2 10%
Cyl3 12%
Cyl4 14%
Cold
Hot
Hot
Leakage Test - Dry
Cold
Cyl1 20%
Cyl2 16%
Cyl3 24%
Cyl4 22%
Hot
Cyl1 12%
Cyl2 14%
Cyl3 18%
Cyl4 19%
Leakage Test - Wet
Hot
Cyl1 12%
Cyl2 10%
Cyl3 12%
Cyl4 14%
The leakage numbers are a bit high. If you can talk down the seller a few thousand, it would cover the cost of freshening up the head. Any records of what had been done to the car by the previous owner?
