968 CS popping out of second gear
Hello all,
As the title suggests on a recent track outing towards the end of the day my 968 kept popping out of second. Usually on lift off of throttle but not exclusively. Prior to this i had noticed second gear seemed to make the gear shift wiggle alot when selected ..
any thoughts
Ta
Phil
any thoughts
Ta
Phil
I don’t think its the synchros. There function is to smoothly transition you into gear, not to hold the gear. I had the same prob w/ 4th. As it turns out, there’s a type of clamp/ring that stops the gears from walking fwd when under load. Mine was mangled and as my gears walked they brushed against the housing and 4th was damaged. Yes big $$$
If it turns out to be something small, you’re a luckier man then I was.
god speed
David
god speed
David
