WTB: Limited Slip, OEM or Aftermarket
I have decided that before I can go on further I need to install a limited slip. If anyone has one available that they would be willing to sell, let me know. I emailed Guard Transmission, hopefully will hear from them soon. Preferably a clutch type, but a Torsen will be fine.
Thanks,
Wes
Thanks,
Wes
well, a car went in for its second pinion bearing job, and the spider gears didn't look good - so, he bought a guards unit in the interest of expedience - the plan was to rework the stock unit and sell it - i'm sure that if you offered him what he would net anyway, he'd do it
Just option codes. The transmission itself is no different. Both the Torsen and Clutch type spin the tires forward. The Torsen was an $800 option, the clutch type, option 221 as I understand it was a $1700 option. The prices today brand new stand at $2347 for a Torsen, and $4100 and some change for a Clutch Type...if you can find one. My rep told me that Porsche Motorsport robbed up just about every clutch type left and made them motorsport 75% lock. This is all heresay, so I can't confirm anything.
Both will spin the tires in one direction, with the only difference being how they work. One uses clutches, the other uses gears. Torsens are the most common among factory cars because they promote better handling (turn in) and are cheaper to produce. The clutch-types are found on higher end LSD's, although BMW has always used them. Either works for me, clutch type is preferable, but at the cost of one, I will pass.
Wes
Wes
It depends on your use. If mainly street either will do fine. The clutch type should be better for the track. On braking a torsen will not lock up from what I am told. I would suggest a Guards unit.
Mike
Mike
Not the motorsport part. I had to call several of my motorsport dealers, and its like $3100 Euro plus shipping was the cheapest I found. After everything was said and done, my bill was like $4200. Then installation, etc... it would be a $5000 ordeal. The reason I was asking part numbers is there are several motorsport diffs, and they all kind of fit. The 964/993/930/968/944 all have different parts, but the first four are completely interchangable. So if the 964 piece is $1500, and the 968 piece is $4000, then I might have to do some experimenting. KAAZ also makes a clutch type LSD for the 964 G50 that utilizes 12 plates with a 60% lock. Its $1300 retail.
Wes
Wes
I've had two units from Guard Transmission (GT) in my S2. The first was a Torsen type and was from the initial production run for the 944. It worked really well on the street and I also drove it on the track a few times, where it also worked well.
For whatever reason... I decided to pull the Torsen type and install a GT clutch type, which was much beefier and had a stronger case compared to the Torsen type unit. It's also worked well on the street.
I find the clutch units a little easier to drive as they seem to be a bit more predictable in how they transfer the power, but I actually think the Torsen type gives better straight line traction, especially in the wet since it will transfer a greater percentage of power to the opposite wheel. With the clutch type, once one wheel starts to slip they usually both let go, which can result in a bit of fish-tailing. That generally doesn't happen with the Torsen type units since the Torsen type is constantly transferring the power back and forth between the two wheels and seems to provide better grip.
I would purchase a GT unit over any factory unit, Motorsports or not, which is much weaker since the cast case on the factory units are prone to break when driven hard... and when it goes it takes the whole transmission with it.
