AC blows water on speed 3 or 4 .... ???
![Unhappy](https://rennlist.com/forums/images/icons/icon9.gif)
Not cool... my 968 is a 1994. Works good at low fan speed but higher fan speeds gets water drops spraying out the vents. Floor boards are dry except by footwell vents where it may blow out of there too....? Any thoughts if this fix is a DIY or do i need to visit the dealer....? Bummer.
Thanks, Deano
Thanks, Deano
Sounds like the drain for the evaporator core is plugged. I don't know exactly where it is for you to fix...
Keep asking around...you might want to ask over on www.968forums.com...
