MAF to Air Box question
Is there supposed to be a rubber seal or gasket between the airbox and the MAF sensor? It has 2 quick clamps that hold it together but the seal doesn't seem that great.
Does anyone know where I can get another one of those quick flip clamps? One of mine is messed up.
Thanks,
Thanks,
Thanks,
Thanks,
Originally Posted by Lemming
There is supposed to be a rubber o-ring there.
Originally Posted by Hughett
Call 928 International or 928 Specialists and they'll both give you advice and fix you up with the right parts.
Harvey
Harvey
1994 968
Thanks,
Harvey
Harvey
I found them and they were able to find the part, it is an o-ring part number
999 707 206 40
Attached is a pdf with the o-ring being #6
The Answer for the quick connect clamps are it comes with the airbox so use mechanics wire or something similar.
For others that might look at this thread
928 Specialists web site
https://www.928gt.com/default1.htm
Thanks again,
