968 Forum 1992-1995
Sponsored by: HBI Auto
Lightweight Battery Mount
Old Apr 25, 2006 | 11:02 AM
Jason Judd's Avatar
Jason Judd
Default Lightweight Battery Mount
I was wondering if anybody is using a light weight style battery, and if so, whose mounting kit they used?
I'm considering a light weight battery for my track car since, according to sources, it can save upwards of 50 lbs compared to a stock battery.
Rennline has a mounting kit that also accommodates a cut-off switch. I was wondering if anybody has tried their unit?
Thanks,
Old Apr 25, 2006 | 11:40 AM
flash968's Avatar
flash968
before you get your hopes up too high, i'm not sure what battery you are using, but a stock one is only about 40# - even if you go to the tiny optima, you ony save 25#, but, that is 25# off the front of the car
that being said, i am moving it to the trunk, and having to make up a kit, so i am interested to see what you find
Old Apr 25, 2006 | 12:30 PM
Lemming's Avatar
Lemming
Jason,
I fashioned a homemade strap for my track car battery (11 lbs) using metal strapping. Works great and I have about $2 in the project (not counting battery costs). The only down side is that I have to unbolt it to remove the battery.
Old Apr 25, 2006 | 01:33 PM
Jason Judd's Avatar
Jason Judd
Tim,
Well, I feel like a real dork!
Guess I was going the "Overkill" route again...
Thanks for the reality check.
Jason
Old Apr 25, 2006 | 02:13 PM
Lemming's Avatar
Lemming
I bought the Braille battery. It came with a hold down system, but I wasn't convinced that it would hold the battery, hence the metal strapping install.
