Flywheel lock
Flywheel lock
We tried to torque the flywheel bolt tonight holding the drivetrain with the brakes. Got up to about 120 ft/lb before we ran out of room to pull the torque wrench. I can't believe how much you can turn the engine with the wheels locked, must have got 90 degrees of twist. Just couldn't get to 155 ft/lbs.
Looks like I need a flywheel lock. I have one for the 928 and the 944, but of course the 968 is different. Anyone have a 968 flywheel lock I could borrow? I'll return it the day after I get it, I promise!
Wow, that is some paint job on your 928S.
I used a thick screwdriver and wedged it into the flywheel teeth through the starter opening. I was under the car with the screwdriver, and my brother turned the wrench on the crank bolt... worked like a charm.
Thanks,
