Coolant recirculation in throttle body
Guys:
I need to confirm the routing of the coolant hoses to the throttle body. I need to confirm if the supply is from the heater connection at the back of the cylinder head and return to the coolant hose connected to the coolant reservoir. Any help will be appreciated. Thanks!
Is this what you want to see?
Here's the three lines at the throttle body, labelled A, B, and C.
You can also see the other end of the connection to point C, also labelled C.
Now for B, it goes to the oil separator:
And A goes to the adapter on the block that takes water from the heater circuit. In the following photo, you can see the hose clamps for both hose A and the heater hose that comes out of the firewall:
Hope this helps.
Clayton
Hope this helps.
Clayton
Clayton;
Thanks very much for your time. This is exactly what I need to confirm. Your help is much appreciated. If I can be of any help, just let me know!
