968 head gasket thickness
How thick are the 2 stock head gaskets for the 968?
Also, does the stock piston stick out of the "hole" at all? Mine's sticking out 0.010"
Thanks in advance!
GM
Thanks in advance!
GM
The head gasket thickness is about 1 millimeter after the head was properly torque (Compressed). As far as I now the deck height should be zero. Pistons with no protruding from the block face (deck). I think that 10 mils of an inch (0.254mm) for deck height purposes is essentially zero. Just my opinion.
