Intake manifold material?
There may be magnesium in the alloy composition but it's going to be mostly aluminum so it'll stand up to a parts washer with no issue. I have a memory of the composition being cast into the part but I may be hallucinating.
Cheers
Cheers
Cliff
Cliff
Extrude hone is an amazing process if you’re looking for a long term, OEM performance modification that will positively affect the resale and longevity of the motor.
Having the process done to the intake, exhaust as well as having the exhaust ceramic coated back to the cat will give a unique growl and preserve the engine bay with lower under-hood temps.
When it’s time, add a quality stainless exhaust and performance cat with a Stg II chip and you’ll have boring reliability that’s maximising its potential without compromise.
It’ll add provenance to the car with modifications known to increase value through conservation that has a side effect of performance.
I had my intake manifold sandblasted years ago.
Still looks new.
944/968 are cast aluminum.
The Cup cars are magnesium, you can visually identify them by their yellow tinge.
Still looks new.
Petethepug - Interested to know if you have modded your car in this way? Ceramic coated exhaust, etc? I've got a Stage 1 RSBarn chip but that's it for now. Ceramic coating sounds like... too much? ¯\_(ツ)_/¯ ... but hey looks count, right?
Well, I'll bite, Extrude Hone isn't all AI enhanced greatness. It is entirely possible to break the casting open, something to be cautious of given not very many 968 intakes have been honed.
Runner diameter increases a little. This tends to decrease the "sharpness" of the torque peak, broadening the peak while lowering the RPM and peak level. This is the effect of the increased runner diameter on the primary resonant frequency.
Am still debating it. On other naturally aspirated cars it gives a feel similar to increased displacement.
Short of turbo conversion or (heaven forbid) Nitrous, there is no one magic thing that turns a stock 968 into a rolling rocket. If you were to extrude hone your intake, install the best headers available with the best exhaust system available and do nothing to enhance the flow of air through the cylinder head, you are still restricted by whatever the flow capabilities of the cylinder head happen to be. Are all of the aforementioned a performance gain? - likely so. But IMHO, it is overkill and not worth the expense or effort for a street car. With all of that done, you will finally be able to outrun, by maybe 1 or 2 tenths of a second, a 2018 V6 Camry from 0 to 60 who's acceleration times are identical to the stock 968.
It is my opinion that things like extrude hone is when you are searching for that last little bit of performance from an all-out race built engine and you are proving those gains with dyno testing.
Cliff
Cliff
