Glove box door and lock wuestion
The hinges of the glovebox are problematic. Fortunately, replacements are available. I disconnected the light inside the glovebox. If that switch breaks(my underhood light switch broke and drained my battery)fails you could drain your battery.
As far as the lock/know is concerned, I have had no issues. Good Luck.
-Yogii
AKA 968 Novice
-Yogii
AKA 968 Novice
Here are some representative products: https://914rubber.com/aluminum-glove...he-944-and-968
Lots of other choices if you search for "Porsche 944 glove box arm".
Cheers
Cheers
Glove box door
I took lock mechanism out along with glove box. Sourced a good lock assembly with key from eBay. Also took apart glove box door to replace hinges, only one there. Apparently I’ll need to epoxy in
It is possible to get replacement lock cylinder to match existing key if you replace/match the wafers in the cylinder, assuming that is a concern.
I looked for the guy who made mine, I think he’s gone somewhere. IIRC, the same guy made them that made my sill protectors and mesh grill and sold them on the 968 forum.
But looking I found this:
I don’t remember installing my aluminum ones being this complicated, but it was a long time ago.
