I have bought an original used Porsche CS steering wheel, but the hub that came with it is missing the splined bottom part that goes over the steering column. I am trying to decide if I can just buy the missing part or if I have to get a new hub altogether. In either case, what is the correct part/hub I need? Photo is my how my hub looks like currently.
The 3 small threaded holes you see are where I removed the plastic/horn ring brass slider that also returns the turn signal. The hub seems to be bolted at the large 3 holes in yours, you can see the rear of the bolts at the larger holes IIRC these wheels/hubs etc.. were made by Atiwe for P so perhaps you can find some Atiwe parts/hubs that will solve for you.
Once you get the right hub you'll need a resistor or some such to turn off your airbag light, too. And a horn contact switch, part no 928-652-104-00. The install itself is super easy and the wheel feels / looks great!
[edit: you're in Australia, so maybe no airbag to worry about?]
Thanks for all the replies.. I believe its a Atiwe 1729x hub I have already, just without the splined part. But if its not possible to get that splined part separately I might just have to get a new one. I already have a resistor for the airbag, but I also need a horn ring?
You will not be able to buy just the splined part unless someone just has one laying around. It’s only sold as a complete hub.
