Tensioner
Hey guys had more 968 now for the summer, was pretty busy so didn’t have much time but I did notice an odd/ loud tick from the front of the engine
it seems like it’s coming from the automatic tensioner, it only happens at low rpm around 1600-2100. It’s smooths out and stays quiet after that
I took the covers off and seemed to have tracked it down to that spot.
after looking online these are NLA, is there a current solution to this or out of luck if these fail now. What do we do?
How did the belts look? I’m no expert, but I can’t imagine what would make the tensioner tick, unless there was an anomaly on the belt that was causing it to move every revolution. As I understand it, all it does is put a constant pressure on the belt.
I agree that the tensioner would not likely tick. A roller maybe. The belt for sure needs to be in good shape. A balance shaft could tick with a faulty bearing and there is a balance shaft very close to that. I just can't imagine that the tensioner is creating the tick. It might sound like that's how to noise is being made, but I would think the source is something else.
I will try and take a video today. Before I got the car it had the timing belt changed. I have to double check the receipts I believe all the pulleys were changed.
I don’t no where or who did the work on that I just have a receipt for parts
