968 belly pan, lining/lower cover
Looking for a 968 belly pan, lining/lower cover under the engine? best price new I can find is $469 from Byers Porsche
Does the belly pan from 944 S2 and turbos also fit?
This is a track car only, so I am open to other suggestions?
I bought a Joe Toth composite splitter, but it is fiberglass, too low, and will not be durable
thanks
Dave
thanks
Dave
If you search over on the main 944 board, there's a post from @T&T Racing that outlines how he made his own belly pan for his race car. I'll see if I can find the post and, if so, will update this.
I'm not completely sure that one from the S2 will fit, but I think this is far enough removed from what's different between that car and the 968 that there's carryover. A quick check of PET will answer definitively, of course.
Good luck
Good luck
I can't help but think that they must help with the aero, but most of what I've read on the 928 board is about lower overall engine bay temperatures. They seem to be designed to pull some amount of hot air out.
Cheers
Cheers
