Cam sensor voltage question
My project continues at a snails pace and I’m being challenged by a single issue with my stand alone ECU. The problem is a CAM Position Sensor signal.
Question: if you have a running 968 and a volt meter, can you post the voltage on Pin 1 of the cam sensor with the ignition key on? This would be on the harness side. Pin 1 is voltage and Pin 3 is ground.
Thanks in advance for any help.
Gene
Gene
