Question about cam cover gasket
Hey guys, got a question about that little rubber o-ring and paper gasket at the top of the cam cover where the Variocam label is. I’ve replaced both once myself and then had them replaced again by a shop when some top end engine work was done. The problem is it still leaks, and the oil migrates over to spark plug holes 3 & 4 and perhaps down to the plugs.
What is it that I’m doing wrong or not doing? Torque specs? I can’t find any specs but imagine it’s only around 6-8 lbs of torque. Please chime in if you know, thank you.
Part#99970169340
Part#94410446302
Part#99970169340
Part#94410446302
Last edited by nitehawk951; 10-22-2020 at 07:24 PM. Reason: Meant cam cover not cam tower.
there are 4 gaskets in the spark plug holes. probably the cause.
get the kit that includes the cover gasket, the spark plug gaskets and the rubber seals for the mounting fasteners.
i torque the cover then tighten the vario-cam seal plate.
inspect the hall sensor wires while the cover is off.
Yogii (10-23-2020)
Part#99970169340
Part#94410446302
Part#99970169340
Part#94410446302
Steve
