Finally!
What color did you use for the powder coat? As others have said, engine bay looks fantastic! Just the firing order sticker missing. I will be looking into the bad idle issue, that definitely affects my car. Some balking, hesitation and hard starting, but runs fine when rpm's are up.
Registered User
I can try find out though if you want.
Registered User
Originally Posted by Isaacsracing
You had the water pump that was leaky in the thread. Did the permatex do the trick?
Dripping from the bottom of that fitting when hot.
Need to find another solution.
I'm wondering if I can find like a rubber gasket sheet and cut my own gasket out to fit behind that fitting and still use the o-ring or Perhaps I should remove the o-ring and just use the sealant?
