968 Forum 1992-1995
968 CS steering wheel
Old 02-13-2019, 10:24 PM
Yogii
Yogii's Avatar
Default 968 CS steering wheel
Just wondering if this is the same as the 968 CS steering wheel?
Sure looks nice.
http://www.rennline.com/Renown-130R-...SABEgJOqPD_BwE
Thanks,
-Yogii
AKA 968 Virgin
Old 02-14-2019, 05:29 AM
LM964
LM964's Avatar
Not really. Correct diamter though.
kingroon (07-28-2020)
Old 02-14-2019, 09:57 PM
oz968
oz968's Avatar
That's the exact wheel I have on mine without the yellow tape to highlight central.
Old 02-14-2019, 10:12 PM
Yogii
Yogii's Avatar
Thanks for the comments. I should have done more research before I posted.
Here looks like the cheapest around: https://www.design911.com/Steering-W...60mm/prod1173/
Seems same/ or very similar style comes in 340mm and 390mm diameter also.
I wonder if airbag delete would **** off CA DMV or my insurance company?
-Y
Old 02-14-2019, 11:11 PM
Jay Wellwood
Jay Wellwood's Avatar
Why would this be an issue? The parts are legally for sale from the OEM in the US and can be installed as a factory issued, US approved enthusiast option.
https://www.sonnenporscheoemparts.co...928347084072jz
Old 02-15-2019, 04:26 AM
LM964
LM964's Avatar
I'm assuming not all 968's US-bound had air bags fitted as standard (from '92 MY)?
Old 02-15-2019, 11:47 AM
Yogii
Yogii's Avatar
California has many strange laws to protect us from ourselves.
-Y
Old 02-15-2019, 12:24 PM
LM964
LM964's Avatar
-Y
Old 02-15-2019, 06:09 PM
FrenchToast
FrenchToast's Avatar
For a modern car, it would technically be illegal, as you would be tampering with a federally-mandated piece of equipment.
In the 90s airbags were not yet mandated, but the car's approved crash-test data was based on the presence of airbags. Removing them arguably makes the car non-compliant in that case. I don't know if there is a provision for allowances after a certain age.
Coming down from the cloud of ignorance, I personally would be wary of driving a car with 30-year old airbag technology unless I knew the history of the car, its storage methods/temperatures, etc. If it's been stored in sun, humidity, etc., I would question them.
I think Porsche recommended replacing the airbags after 13 years? Nevertheless, it's first-gen airbag tech. There have been several accounts on the 964 board of spontaneous detonation from prolonged vibration.
All U.S.-bound Porsches had driver and passenger airbags fitted standard starting in MY90.
Old 02-15-2019, 09:31 PM
Yogii
Yogii's Avatar
Thanks for all the responses. I would love to add a CS wheel. What is the diameter of the air bagged four spoke wheel?
-Y
Old 11-21-2019, 08:50 PM
Jayck
Jayck's Avatar
Have some of you did the airbag modification for no airbag models?
what do you do to bypass the airbag switch?
Old 11-23-2019, 03:55 PM
Yogii
Yogii's Avatar
The procees is explained somewhere on the web. Do a search and you should find it.
-Yogii
Old 11-23-2019, 04:15 PM
Jayck
Jayck's Avatar
-Yogii
Sorry i've misspelled! I was asking FOR airbag models...i keep falling on video's of people swapping steering wheel without airbags but no with...i'll keep searching 😋
Old 07-15-2020, 10:12 AM
Eleasar
Eleasar's Avatar
Hey guys, looking replacing my airbag wheel with a non-airbag wheel. However, doing some research on the web, in Virginia the insurance coverage will likely go away and the state does not allow the tempering with airbags. The main reason I'd like to have an aftermarket steering wheel is to bring the wheel closer to me. I was not able to find a spacer for the original 968 airbag wheel, which would be the best solution. Even searching the different forums I am only able to find the replacement with an aftermarket non-airbag wheel and the 993/996 option, which does not seem to move the wheel any closer to the driver.
Thanks!
Old 07-15-2020, 03:42 PM
Yogii
Yogii's Avatar
Hope this helps...
https://www.google.com/imgres?imgurl...MygHegUIARCiAQ
Otherwise, have you thought about a deeply dished steering sheel?
-Yogii
AKA 968 Novice
Quick Reply: 968 CS steering wheel
