Accessing door lock actuator
New User
My passenger door lock stopped locking when the key is turned in the driver's side lock. In the past both operated with the key, and I assume that's the normal manner. The passenger door lock can be operated manually, however. I suspect the problem is an electrical component called an actuator, and I find these for sale on eBay. If my diagnosis correct, do I remove the door panel off to find the actuator, assuming that's the problem?
User
