Replacement Headlight Bulb??
PIAA is a well known name of lighting products. Can be found through a variety of outlets. Their extreme white series seems to have the highest color temperature of their products. http://www.piaa.com/Bulbs/Bulbs-H4.html
Note that if you pick up an application catalog at a local parts store, they typically list a 9004 bulb for the 968. This is not correct. The 968 uses an H4 bulb for the headlamps.
