968 dip stick length
Hi guys. Would one of you guys measure the length of the 968 dip stick from upper O ring seal to the dip stick tip and post it here. I broke mine today . Thanks in advance!!
Boeing. Naw, I will pick up a real one from parts heaven over in Hayward Calif tomorrow. My 951 is sitting next to the 968 in the driveway so I used it to get a reading today using that measurement I was given by spokaman
I have never has the oil pan off of one of these. I will assume there is a wire mesh screen on the suction line leading to the oil pump inlet so I dont need to really worry about the broken section of dip stick that fell into the sump, RIGHT?????
Registered User
Registered User
Originally Posted by spark1
After you disconnect the tie rods, control arms (A arms) and power steering hoses. The cross member (with the steering rack) and the oil pan are a breeze!
