SFR 968 supercharger
I just wanted to let you all know that we have made a few changes to the 968 supercharger system.
We decided to use a different self contained ATI unit which is actually smaller and more efficient
then the last unit we were using.It is fully CNC'd including the compressor wheel! All of our bracketry is CNC'd now and the best part is that we will be offering two versions of the kit.A low boost alternative and then a moderate boost alternative.The later set-up just generated 313 at the wheels which is an improvement of 7 horsepower over the last blower run at the same boost level.We also worked out a way to use the stock coolant resivoir which will help keep the system looking a bit more stealth. So that is about it. If you havent ordered one of these set-ups, now is the time to do it! You can get them through SFR if you are in the states or 9M if you are in Europe.
Tim
Do you have any pics new set up with all of the CNC stuff? Also do you have to send the car to you or can it be done by a competent owner and is there a price change?
Craig
Craig
Originally posted by TurboTim
I have some pictures of the new blower and brackety but no way to post them.I can send you pictures via email but I would need you email address.
No A/c with our kit guys.The S2 uses the same blower now.I have a membership card,number and all that and when Rennlist was reformatted recently, my membership designation disappeared?
