Dyno pull!
Dyno pull!
I had the chance to get my 968 engine swapped S2 onto a dyno the other day and thought i would post it up here since im swapped. The motor is stock, with the thick headgasket, the thick gasket happened as it was all i could get during a road trip emergency. The DME does have an RS barn chip that looks to have me running a bit rich up top. Ultimate numbers were 172hp @5750 and 169ft-lbs @4500, these are uncorrected for my altititude which is 6,000ft. Pretty much right where i expected. The dyno was a Dynocom 5000.
The
The
It would appear that the vario output is set to always be on from the dme, it sees full voltage at all times. I just checked it with my DMM while revving above 1500rpm. I would expect to see zero voltage at idle if it was off right?
Hmmm the motor was cold when i checked the voltage at low RPM... My understanding was 0-1500ff 1500-4500: On :4500+ off. But if it was cold that would maybe make sense. I think ill call RSbarn on monday and chat about how they handle the vario. I do feel like its missing a little bit up top, that would explain it if it was always advanced.
It just seemed your curve dropped off too soon.
i may be wrong, but I believe the idle validation signal is at the pedal, not the TPS with the 968 control unit. You might pin a diode with a 10k ohm resistor at the ECU and go for a run.
Corn fuel has ill effects so I usually won't push the limits on the mile high roads unless I tank up at co-op with real gas.
edit...'chips' generally go open loop at WOT so you might check the programing when you make the phone call. that might explain why you where running phat/rich. see if they can burn a chip that uses the o2 sensor at wide open due to your elevation
