968 A/C Low Pressure Valve
Hi,
Does anyone know where the low pressure valve is located on a '94 car?
I'm trying to charge the system, and could only find the high pressure one near the driver's headlight.
A picture would help a lot!
Thnk you.
Rod.
Thnk you.
Rod.
Registered User
Originally Posted by Bola964
Hi,
Thnk you.
Rod.
Thnk you.
Rod.
Locate the low side line (compressor to evaporator), largest diameter hose exiting compressor. Follow it up the driver's inner fender, it heads toward the rear of the motor. I recall they moved the service ports in later years to make it more accessible.
Porsche 968 Air Conditoning
