Difference between G50/50 & G50/52 Trans?
Anyone know the difference between these transmisions. I know the G50/50 was in the 89 930 and the G50/52 was in the C2T.
Justin
Justin
Lead Rennlist
Technical Advisor
Lifetime Member
Lead Rennlist
Technical Advisor
Lifetime Member
Dear Justin,
The type of limited slip diff is one difference. The G50/52 uses a 20/100% LSD developed specifically for the 964 Turbo and fitted as standard. Gear ratios are also different but I would have to check.
Ciao,
Adrian
964C4
Ciao,
Adrian
964C4
