1st go pro, idle with walk around
Finally access to a GoPro
1st video , walk around while idling , Turn up sound or head phones , More to come
https://www.youtube.com/watch?v=s6c5...ature=youtu.be
The only car I would buy in black. Awesome/gorgeous/beautiful/khoobsurat/pretty etc etc
I personally would change the turn signals to white and get some tail pipes (not sure black/aluminum) but something that sticks out from the back.
Be careful
Be careful
I bought my car with clear corners and I couldn't get them off fast enough.
Stefan, nice idle. Those Turbokraft cams must have a lot of overlap.
Thanks,
that was 1st video
I have some with go pro on rear window - too quiet
some with go pro below rear wing stuck on rear deck lid ..still quiet
must edit and I will post
I have been extremely busy
the cams sound radical BUT have good off boost performance pulling clean from 800 RPM
that was 1st video
Well,
I'm running 0.8 bar spring
In the next video (about to post) you can start to get the idea .. I have too much wheel spin
the video does not really capture the wheel spin or acceleration
1st is useless
2nd breaks loose even if I just roll on the pedal
3rd will step out
stefan
1st is useless
3rd will step out
stefan
I've searched a bit. In a nutshell->
Ported
Cams
Programmable ignition
Adjustable WUR
044
Flame ring.
Lighter FW (better acceleration in short gears).
But I am doubtful about the turbo. Is it a K29 or a K27/29?
Congratulations for the car.
Ported
Cams
Adjustable WUR
044
Flame ring.
