noise from driver side
To answer both questions.
Non mechanical noise. Sounds like air/wind, outside noise, I see a little cut in the seal and when I mess with the door, open/close it feels like there is a gap......should i replace them anyway and see if that fixes it?
Guessing that your door seal is aged (looses the bulb) and the door probably needs to be adjusted. Go to a good body guy.
I did this on my 930 and it made a lot of difference. Will be doing it on the 964T. Check your door hinge/bushing for wear (play) and door gap when closed.
