964 Turbo Forum 1989-1994
Picture of CatBypass installed.
Old 09-01-2014 | 02:50 PM
MeanMachine's Avatar
MeanMachine
Default Picture of CatBypass installed.
Hello,
have just purchased a Catbypass and the muffler delete which sort of "U" shaped.
Does anyone have a picture of Catbypass pipe along with G neck installed? I want the picture under the engine to get an insight to how it's installed.
I tried searching could only find 964 NA.
I will be removing my Cargraphic muffler, only going to use their wastegate pipe w/tip and from my K27-7200 will be installed to a Cargraphic cat bypass pipe along with G neck. For the G neck, it will be paired to a set of Cargraphic tips which will be same as the one came on my previous setup that I will be using their wastegate tip side.
From my waste gate I will be running the bypass pipe that came with my current set up( cargraphic muffler) that had a nice tip.
I have placed an order for similar tips from Cargraphic, so they can bolt on to the G pipe with no welding and via clamps or oem style.
After I am done I hope to get a louder idle and a turbo spooling sound, which I wish to achieve on my Turbo 3.6
Old 09-01-2014 | 08:00 PM
Bernard's Avatar
Bernard
Not sure if this is what your looking for? Its the only picture I have of mine installed. I removed the G-pipe after test driving it, to loud for me.
Old 09-01-2014 | 08:15 PM
MeanMachine
You have oem headers right ?
Old 09-01-2014 | 08:52 PM
Bernard's Avatar
Bernard
Yes
Old 09-01-2014 | 08:59 PM
MeanMachine
Because I see you have the "Swans Neck" after the Catbypass,
I have B&B headers and Cargraphic Muffler, the oem final muffler is deleted in my car.
Old 09-01-2014 | 09:05 PM
Bernard's Avatar
Bernard
I have the Fabspeed cat bypass, muffler delete and tips. I would of put some headers on but it looks like my stock ones have never been removed so I don't want to try to remove them and break the studs.
Old 09-02-2014 | 07:03 AM
MeanMachine
I can understand that, the headers will reduce lag.
Does anyone know what
Clamps and Gaskets that I need, the parts from Cargraphic come without installation items.
I want to fit the exhaust tips, anyone have the OEM clamp part number ?
I Will fit the G neck to the Catbypass, anyone have part number for Clamps or required parts ? Where can I get a new gasket etc.
